checking 650 valves warm or cold tight or loose
Old Jun 25, 2004 | 12:04 AM
wildrides's Avatar
Default checking 650 valves warm or cold tight or loose
I read adjust valves on cold motor. Is this correct.
Do these vavles make noise when they need adjusting. I heard they make no noise.
is .10mm better than .15mm for intake ? the same
is .20mm better than .25mm for exhaust or either is ok
Old Jun 25, 2004 | 04:29 PM
nyroc's Avatar
Yes, do em cold. Set them in the middle of the spec as best you can. I couldn't hear mine before or after the adjustment.
ltrmc02
Jul 22, 2015 04:50 AM
95wolv
Jul 17, 2015 08:13 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Unzzy66
Jul 11, 2015 10:01 PM
