Module Install
Old Aug 3, 2004 | 05:54 PM
SaskRider's Avatar
Default Module Install
Just wondering if I could have done something wrong with the install. I just picked up a used nabor module and I'm sure it works fine... hooked up the three wires and the bike starts and runs just fine but i really can't tell that much of a difference. I know that the 27" 589's on the front are heavy pigs but it's definitely not a wheely machine like some of you guys are talking about. I guess I'm wondering if the bike would still run even if I got some of the wires crossed?
By the way I'm running an 04 STP 700 with the EPI black secondary and no other mods (besides the rubber)
Perplexed...
Thanks ahead of time!
Old Aug 3, 2004 | 07:53 PM
Kawi650's Avatar
Other issues you might have to address like your belt might be out of spec, clogged airfilter wrong jets etc.. There's different types of frequency thingys that do different things, and 700s are also are a little open from factory than the 650 was so it's not as noticable but still it should be noticed. Also you might have to do some work on your front spring too to get more with the bigger tires.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
