got a ?
Old Aug 28, 2004 | 08:40 PM
snowman610's Avatar
Default got a ?
if i put a pipe on my prarie that increases it by 10 hp and i re jet it how much faster would it be
Old Aug 28, 2004 | 08:53 PM
snowman610's Avatar
Default got a ?
does anyone know???
Old Aug 28, 2004 | 09:19 PM
redbruteforce's Avatar
Default got a ?
the manufacture probably means 10 hp by doing everything. that sems like a big number but when ever you buy a pipe, the instuctions say that you have to rejet the carbs when you install this product because if you install a pipe without rejetting it the motor will run to lean, you won't have maximum power and will eventaully burn up the motor.
Old Aug 28, 2004 | 09:27 PM
snowman610's Avatar
Default got a ?
ok but wut would be the top speed after all of that??
Old Aug 28, 2004 | 09:39 PM
Default got a ?
It's hard for me to say, every machine will react differently to it but with all that extra hp, you might just accelerate like a bat out of hell until you hit the dredded rev limiter
Old Aug 28, 2004 | 10:23 PM
NovaKaw650's Avatar
Default got a ?
10hp from a pipe? Not likely!! Pipe, intake mods, ignition work, cam work - maybe. How much higher would the top speed be if you could actually get 10 more hp? Not much; there's much more to getting a higher top speed than just adding horsepower. BTW - what kind of Prairie are you talking about?
Old Aug 29, 2004 | 01:58 AM
kawiyowee's Avatar
Default got a ?
I would really look sideways at whoever told you 10 hp from a pipe. One hp would be more like it imo.
Old Aug 29, 2004 | 10:07 AM
Metallikev's Avatar
Default got a ?
I agree with kawiyowee...maybe they meant 10 percent more power..that might be a bit more realistic...
Old Aug 29, 2004 | 01:18 PM
Customfabandweld's Avatar
Default got a ?
10% sounds right. A pipe is definetely worth it, either way!
Old Aug 29, 2004 | 08:41 PM
BigSix's Avatar
Default got a ?
wow 10 hp off a pipe thats almost as good as my stickers that added 15 hp....lol...(available now pm for details...)but i agree with ^ 10 percent is more likely...and when you are adding power its going to aid in acceleration more than anything....
