Dyna CDI or DG5
Old Sep 7, 2004 | 04:47 PM
rubione's Avatar
Default Dyna CDI or DG5
I know there have been very little if any comparisons with the different modules for the Brute. I have no experience with these. What knowledge I have is from reading the different forums. Does anyone have any idea as to which of the above units would provide the better overall performance enhancements? I know the CDI is a plug in unit that replaces the stock CDI. This would be the easiest to install. However, I would go with the best overall performance. Any help will be greatly appreciated.
Old Sep 7, 2004 | 07:38 PM
DaveB's Avatar
Since the topic is going.......does anyone know if the Dyna CDI for the Kawi700/AC650 works for the BF750?
Edit: nevermind.....answered my own question by visiting the Dyna website...they are the same part#.
Old Sep 7, 2004 | 08:56 PM
redbruteforce's Avatar
what is dynatechs website address?
Old Sep 7, 2004 | 10:54 PM
HavinSomeFun's Avatar
try this
http://www.dynaonline.com/english/index.htm
Old Sep 8, 2004 | 02:26 AM
travelor's Avatar
I put on the dg3 first then added timing key. Got expensive having dealer no everything. First dg3 didn't work. 1 hr labor then second dg3 1/2 hr. then key 2 1/2 hr. then lost top speed somehow still don't know why so had them check it again another 2 1/2 hr. to make sure in right. Then wasted more time trying to get them to retard cam timing. The dyna advances to 33* with out key and holds the timing at the end while the dg whatever probably will not. Easy to install dyna.
Old Apr 27, 2005 | 12:27 AM
snowdogs's Avatar
i installed the dg5 today and it gained very little over flipping the switch to off . i have 26 mudlights on it, and i have to work to get it to wheelie. Did i get a bad one? it seems alot of people said the difference was incredible. Putting in the black secondary spring and the maroon primary spring had a much better performance gain??/ help anyone thanks
Old Apr 27, 2005 | 11:11 AM
tuffEnuf's Avatar
Sounds like wiring or you got a dud. Double check your wiring & voltage to module & DG recommends soldereing connections. I had the original holeshot module and full throttle would stand it on the bumper below 10MPH[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 27, 2005 | 01:43 PM
NewBF750rider's Avatar
I had the same thing happen to me. I called in and some engineer called me back and asks me stuff about the flashing led. Turned out to be a bad connection on one of the wires. When I fixed it and tried it, I almost flipped over cause I wasn't expecting it so much.
Old Apr 27, 2005 | 06:10 PM
alltoys's Avatar
You can replace a module with the simple installation of an EPI Red Spring. The spring engages at 3500 rpm the same rpm that the module advances the timing to. A CDI is the only way to go performance through the whole spectram of rpm range.
Old Apr 29, 2005 | 04:23 PM
bmanduley's Avatar
i definately like the dynatech cdi that's on my prairie 650. [img]i/expressions/face-icon-small-smile.gif[/img]
lawnboy
Apr 18, 2004 07:37 PM
MikeyBoyesq
Apr 16, 2004 11:06 AM
MikeyBoyesq
Apr 16, 2004 08:34 AM
PrairieDust
Apr 3, 2004 07:51 AM
RaptorRacer1
Feb 27, 2003 02:33 AM
