#42 or #45 pilot jets
Old Dec 3, 2004 | 06:43 PM
STAKK's Avatar
Default #42 or #45 pilot jets
The brute use a #38 pilot someone used the #40's from the Prairie's in their brute on another forum......don't know about #42 or bigger.....JR Grahm has alot of carb parts though try there......
Old Dec 3, 2004 | 07:22 PM
kwackermann's Avatar
Sonce you've donw all that with the air screw- then a larger pilot is in order- but I'm at a loss as to whcih size..
Old Dec 4, 2004 | 09:47 PM
tuffEnuf's Avatar
PrairieDust. With those big tires try a different primary spring. I like the Dalton Orange/Blue, but the EPI red may be a better choice to restore bottom end power & get power to those 27" Meats you're running. The Red spring has more stall than the Orange blue and takes some getting use to and fettering the throttle in off camber/tricky hills.[img]i/expressions/face-icon-small-smile.gif[/img].
With my mods I can get on the throttle harder on takeoff now without it coming up & over so quickly.
With the #42 pilots I had to turn my airscrew all the way in to 1 turn out at the most with 138/142 Keihins and it as still puffing black smoke at idle and you could'nt be in an enclosed room when you started it without your eyes immediately watering and gettin lightheaded.
Be sure your slide springs are in properly (shim did'nt fall out or spring binding when putting slide back together), your throttle cable is adjusted properly and not binding (turn your handlebars & see if it affects idle speed) your choke is not sticking & you don't have any air leak around your carb manifolds.
Try the Dyna, I think they got the bugs out now, at least the second one I got has performed flawless so far. Night and day difference from stock & extremely wheelie prone.
[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 4, 2004 | 11:57 PM
traindog71's Avatar
The pilots are the N424-22-XX Series of pilots, 28mm in length, available from carb parts warehouse online, www.carbparts.com
Old Dec 5, 2004 | 07:55 AM
  #15
cueball89's Avatar
pilot jets i think they sell jets, im not sure what number though.
ReconBayou
Oct 31, 2022 05:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
