VDi timing advance module
I agree with you, like I said in my review I am not a fan of those connectors but they do simplify installation for the general public. I plan on installing a VDI CDI in the future and it will be easy to remove the module due to the connectors that came with the kit. If I knew I was keeping it in there I probably would have soldered and heat shurk the connections. Now all I would have to do is solder one wire and heat shrink the cuts in the insulation where the module attatched.
