Wheel spacers on V-Force
Old Dec 28, 2004 | 11:15 PM
Kawierider's Avatar
Default Wheel spacers on V-Force
I put some 2.5" EZ Fit spacers on the back of my V which really enhanced its stability (and matched up to my new offset front wheels), but I'm wondering if these things seriously compromise the strength of the hubs or lugs. Has anybody broke anything by running spacers?
If this was a 350 pound racer, I wouldn't worry, but at 516 pounds, I'm concerned. It's strictly a dune quad, and I do some mild jumping.
Old Jan 4, 2005 | 08:55 PM
Spaz40's Avatar
I have used the dura blue wheel spacers for over a year now 2 1/2" per wheel 5" total and have had no problems. I wouldnt ride without them any more. It does make it a little tight in the woods but it is worth it. I had the 1 1/2" spacers on the front but did not like the steering after that so I took them off. I do ride very hard so I if any body was going to bend an axle or something running wheel spacers it would be me. Hope this helps.
Old Jan 5, 2005 | 09:32 AM
newbeatle's Avatar
I would honestly be worryed about big air on hard pack, with spacers that wide, but as long as you keep them good & tight, you'll likely be OK on the sand...
Old Jan 5, 2005 | 03:58 PM
Kawierider's Avatar
Thanks for the input. I've got two rides so far at Glamis with light jumping, and no problems so far. The handling was significantly improved. I can honestly do doughnuts with the big 24" Skat Trak Extremes. Before the spacers, that was scary because those tires grab so well. On my first ride, I parked after about 5 minutes and re-tightened the lug nuts. That turned out to be a good idea because there was a little slack to be taken out after the initial install.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
