re-jet with CDI
Old Jan 1, 2005 | 01:25 PM
ChaosInMt's Avatar
Default re-jet with CDI
The CDI will have no effect on how lean or rich you are running. As for what jets you need to run you have supplyed no information at all about your quad or enviorment. I.E. what quad what mods. what altitude and latitude. and what it is running like now.
Old Jan 2, 2005 | 02:12 AM
shortyno11's Avatar
so it wont make a difference in lean or rich?
Old Jan 2, 2005 | 08:52 AM
BunnMan's Avatar
No, CDI's shouldn't effect jetting much. Jet size is more a function of how much air the motor can pump on one cycle. That's why the airbox and exhaust mods require jetting. Those mods directly effect airflow.
HOWEVER a CDI can reveal a mixture problem that was there to begin with. If you are running a tad lean with a stock set up and then change to a CDI that advances the timing curve you may experience detonation sooner. The lean condition may have been there all the time but never caused much trouble due to the mild timing curve. Also, many here have testified that the low end miss on the BF750 is due to a lean condition and gets worse with a Dyna CDI. In that case the problem was there all the time and gets magnified by the more aggressive timing curve.
Whenever you move toward higher performance you also move toward a more finicky motor. That is not to say high performance is a bad thing [img]i/expressions/face-icon-small-smile.gif[/img] but is is to say that along with the intended mod usually comes some tuning. A decent tuner can get a little more punch out of a motor and still get reliable operation as well. Few mods are true "bolt ons".
Sometimes when I give my 2 cents, folks will hand back change [img]i/expressions/face-icon-small-smile.gif[/img]
God bless,
-BunnMan
Old Jan 2, 2005 | 03:41 PM
ChaosInMt's Avatar
Bunnman Great explamation and tact to (something Im always told I lack) it,s all in the tuning. Mods dont mean anything if your quad does not run right. How do you think I win all the events I do on a 650 TUNING . (and a few more mods than I have listed)[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 4, 2005 | 02:06 AM
  #15
shortyno11's Avatar
thanks a lot guys.
Old Jan 4, 2005 | 12:19 PM
  #16
cc1999's Avatar
I didn't rejet at first, but when I later had a chance to test my STP700 with a stock STP700 I discovered I had actualy lost a little. On the dyno it was showing to be safe but we have found this motor likes to be almost rich for optimal performance. I would say if the CDI is all you did you are ok. I have a Procircut exhaust, dyna CDI, and K&N filter. Its when you start combining mods that it starts to get to lean to perform. its been rejeted now useing the dyno and ehaust sensors. to give you an example at the rear wheels stock is 30 to 32 hp mine with all the mods was only 30 hp befor the rejet after rejeting for the mods we got it up to 37.5 hp. so to answer you question you do not have to rejet but to get your optimum gain you may want to especialy if you have other mods.
Old Jan 5, 2005 | 02:08 AM
  #17
shortyno11's Avatar
thanks.
Old Jan 5, 2005 | 02:10 AM
  #18
shortyno11's Avatar
what brand should i get?
Old Jan 5, 2005 | 07:08 AM
  #19
skooter525's Avatar
Yo Bunnman, Hey neighbor. Where in Md do you find to ride? No where right? LOL I go to Tower City, ever been there
Old Jan 6, 2005 | 12:14 AM
  #20
ChaosInMt's Avatar
I only know of one brand that makes a real CDI thats Dynateck. The rest are not CDIs just ways to fool them. That does not mean they are bad.
JohnnySplat
Aug 6, 2015 12:07 PM
SMW
May 18, 2001 04:40 PM
ssimons
May 20, 2000 10:08 AM
tomuchfun
Mar 16, 2000 06:20 PM
