Whats wrong with the ole' trusty 360
The guys all said for you to fix the fan. Have you fixed the fan?? The reason your oil light came on is because the oil got so hot that it no longer had any viscosity. You then lost your oil pressure. The gas is indeed boiling and causing vapor lock. Please fix the fan, and change the oil.
Yes either your fan, fan switch, a fuse or maybe the wiring to the fan is bad and likley causing the other problems since it is running way too hot. I would suggest that you not ride it until the fan is fixed as you could do some damage to the engine internals.
I finally broke down and took it to the shop. I was going to try and do the manual switch but I couldn't figure out how to make it work. It was time for the service anyways and I got to take a good look at the BF750 and BF650. They both look like great machines.
