milky stuff in oil ?????
Old Dec 30, 2004 | 04:52 PM
tmaxx's Avatar
Default milky stuff in oil ?????
I went to change the oil in my lakota today and when i unscrewed the oil cap, there was a bunch of white foamy stuff in the top of the cap. Then I noticed that it was in the oil draining out of the engine too.
What is this crap?
Old Dec 30, 2004 | 05:08 PM
Nicname's Avatar
Usually, any foamy or milky substance in the oil is water contamination. Change the oil immediatley. Then find where the water is getting in. Any sign of water in the oil isn't good.
Old Dec 30, 2004 | 06:16 PM
newbeatle's Avatar
yep... water... just a note, that if you get any water splashed into your filter box, it will go into your oil through the crank case vent... unless you extend that vent to a higher location, outside of the filter box...
Old Dec 30, 2004 | 06:49 PM
MOJAVEalltheway's Avatar
oil and water clean it out good and find the leak and fixer up or ull have it siezed up in no time
Old Dec 30, 2004 | 07:09 PM
tmaxx's Avatar
How should I get the rest of the foam out? Would doing a double oil change take care of it?
And I,m not quite sure where the vent is your talking about.
Old Dec 30, 2004 | 07:35 PM
bubsbf750i's Avatar
yeah, what i would do is change the oil run it about 10 mins drain oil and repeat as needed, it took me twice on my BF but it did it 3 times to be safe.
Old Dec 30, 2004 | 07:45 PM
tmaxx's Avatar
Does anyone know if it will hurt to run the engine without the oil filter in it for a few minutes. I want to run a few changes of oil through it, but dont want to have the filter in there if it has water in it.
Old Dec 30, 2004 | 09:05 PM
bubsbf750i's Avatar
i wouldnt, just change the filter after u change the oil a couple times..
Old Dec 30, 2004 | 09:59 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
I wouldn't because for those few minutes dirt could get in, and oil is going to be leaking out of the oil filter hole..
Old Dec 31, 2004 | 12:00 AM
ranger696f's Avatar
have the jug checked and replace all the gaskets and rings
