P700 runs kinda hot
Old Jan 2, 2005 | 02:47 PM
Kegbasher's Avatar
Default P700 runs kinda hot
I have an 04 prairie 700 with 28 gators, and a high lifter lift kit, other then that it is stock. No matter how hot or cold it is out this thing likes to run on the hot side. I am always making sure the radiator isn't packed with mud. It also seems it runs a lil on the lean side as well. Could my temp. problems be coming from improper jetting? Could it have come from the factory with lean jetting?
What can I do to help keep this thing cool?
Old Jan 2, 2005 | 02:50 PM
fox250racer's Avatar
Yes it could. The reason its running hot is b/c your jetting is running lean, rejet it as soon as you can!
Old Jan 2, 2005 | 07:05 PM
vtwinriot's Avatar
Also switch to a fully sythetic oil and install one of the modules or a new cdi. These will get rid of the timing retardation which can also lead to hotter temps.
Mphillips
Jul 29, 2015 08:53 PM
Mphillips
Jun 26, 2015 03:52 PM
Dabears1983
Jun 16, 2015 12:17 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
