Upgrade from stock
I have a o4 700 prairie with 26" itp 589's i was wondering what would be a good clutch kit for my quad i ride mud i get into some pretty deep mud from time to time 65% of my riding is rough terrain also is the cdi worth the money for what i ride in what is the best one
thanks
thanks
I would suggest dalton Orange blue primary spring for a little snap, EPI black secondary, no weights, and Dyna CDI. You will be very pleased with that setup. If any of those things on mine were to break, I would be on the phone the next day to replace them with the Identical item. (or keep your stock 700 spring if you dont want any stall). (If you dont care as much about top speed the DG5 will be great and save some money). My .02 cents
Thanks Rivermud where is the cheapest place too order this stuff i live right on the border in canada so i can pick it up in Maine at a buddys place when you say stall you mean engine stall
By stall I mean when you hit the throttle and the RPMs go up, the clutch waits till the RPMs are a little higher before it engages. That allows the engine to be closer to its peak power range before it goes. For the springs I would call dale dalton directly since your in Canada (he is too). For the CDI you can go to the Dyna website or even get one on ebay (they are there all the time). I would give you the numbers and websites but I dont have them with me right now. (not at home). You can do a search and find them all pretty quick though.
