epi red spring bf750 ???
Old Mar 5, 2005 | 12:19 AM
swampbf750's Avatar
Default epi red spring bf750 ???
i only weight 147lbs and the weights are stock and i took .030 shim out and .040 shim out belt was to tight so i put the .040 back in know it is back to stock but i am now thinking it is the belt does any one have the belt thikness thanks
Old Mar 5, 2005 | 11:34 AM
tuffEnuf's Avatar
SwampBF750
So how did it run once you corrected the belt deflection? I am assuming You are running in 2WD?
Find a friend to swap your ignitor/CDI and see if thats the problem.
If you are having to put a shim in secondary and have not tried to pull somebody out of a stuck in 2WD and glazed/burned your belt, I'd say your belt is good. You should know whether you've pulled something extremely heavy in 2WD or attempted to pull something and your rear wheels were not moving. Inspect the sides of belt for glazing.
Do a search on DAYCO Belt. Seem to recall post that had measured the lengths and thickness. I'm not recommending the Dayco since the Stock 700 belt is the way to go. [img]i/expressions/face-icon-small-happy.gif[/img]
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
