mojave paddle tire recommendation
I always thought skat trac 21 12 8s were a good tire for any atv but you have to change your hubs to run those. What are you trying to do with you atv? Like hillclimbing all day or just doing lots of sidehills and turns? If your doing a mix of both go with the 20 11 10 Sand stars
It'll be for bowl riding, moderate hill climbing and jumping.
I have a question? For hill climbing you recommend 21x12x8 and for a mix you recommend 20x11x10. And the stock size I have right now are 22x11x10. Does the variation matter? Is the numbers the same as a car tire... height x width x rim diameter? Please explain.
Thanks
Thanks
yes it is h X w X rd just like a car tire. With the 21 12 8s you get more of a round profile which i hav liked for climbing in the sand. And with the 20 11 10s sand stars are a good all around tire because they turn like a v-blade paddle but climb like a straight blade paddle.
And since you are in sand and sand slows you down going down from your stock tire size is a good idea.
