Oil Change Procedure??? Standing the atv perpendicular??
Old Jun 15, 2005 | 11:51 PM
GR8Outdoorsman's Avatar
Default Oil Change Procedure??? Standing the atv perpendicular??
My Kawasaki mainenance manual says that I should stand the atv perpendicular to the ground when I change the oil. Is this necessary, or can I just change it like any vehicle????
Old Jun 16, 2005 | 11:37 PM
rolsmojave3's Avatar
you can change it like any other vehicle...it's easy to get at if it's on the rear tires though
Old Jun 17, 2005 | 10:00 PM
Thanks,,,,,,,,, I didn't think that it would make that big of a difference, but I wanted to make sure.
Old Jun 18, 2005 | 12:58 PM
Kawizuki400's Avatar
Now you never know though, your quad might have a really strange oil pan or something and need to be tipped rearward for the oil to reach the drain hole. Try the best of both worlds to be sure. Drain the oil with it sitting flat on the ground and then tip it rearward for a moment. If you get anymore oil, then you know Kawasaki wasn't just interested in seeing you struggle to lift your quad up. If you don't get anymore oil, give your manual a funny look and then change the oil as your normally would.
Old Jun 18, 2005 | 04:50 PM
Good idea,,,,,,,, I will give that a shot
Nosniborpapa
Sep 12, 2015 05:54 PM
bigbear350quad
Sep 11, 2015 12:40 PM
ylomnstr
Sep 10, 2015 11:08 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
