smoked my belt!which belt to choose.help !!!
LAST WEEKEND I SMOKED MY BELT WHILE PULLING A GUY OUT OF SOME THICK STUFF. IN REVERSE.I WENT INTO LIMP MODE SHORTLY THEREAFTER.WHAT BRAND SHOULD I REPLACE IT WITH.KAWI-$120--CARLISLE-$85--OR DAYCO HP $50--??? ANY COMMENTS OF EITHER OF THESE BELTS AND THEIR LONGEVITY....THANKS..ROB..[img]i/expressions/face-icon-small-confused.gif[/img]
Can't answer your question on which one is better but i will say make sure you pull people out going foward low and not in reverse which i'm sure you have figured out. Reverse is where the brute smokes its belt or so i'm told.
Stay away from the Dayco belts , they are garbage . Stick with the Kawie belt and you will be happy. Don't know anything about the Carlisle belts , but i have tested more than 6 Dayco's , all with similar results.
Hey jpsdiving , i noticed in your sig your are testing the Dayco and Carlisle belts. How has your luck been , as i had none with the Dayco's . The problem i had with the Dayco's was i could not get them even close to within spec. for tightness , even removing all the shims , which just caused them to slip, get hot , and grenade.
THANKS GUYS FOR THE RESPONSE SO FAR.FIRST MISTAKE I MADE WAS PULLING IN REVERSE.WON'T HAPPEN AGAIN!!I'LL GET THE KAWI BELT I THINK.(GO WITH FACTORY ORIGINAL ).CHEERS.ROB.[img]i/expressions/face-icon-small-happy.gif[/img]
HY, I am having great results with the new dayco proto type. I can't wait until this belt is available to the public. It seems like dayco stepped up and produced a great belt for the large bore quads that should hold up just fine. I have no problem setting deflection, and the belt runs really strong. Long term testing will prove me right or wrong[img]i/expressions/face-icon-small-smile.gif[/img]
hey juicee
my local dealer here in terrace BC told me 165 plus taxes.
so 120 is a deal.
what was the name of the place you got you quote from.
i think i might try and contact them.
so 120 is a deal.
