problem with 99 mojave
Old Jun 22, 2005 | 08:29 PM
dkmojave's Avatar
Default problem with 99 mojave
hey whats up my mojave has a prob with cutting out it did it before and i changed the plug and it ran fine for a while and starting doing it again and this time when i pulled the plug out it was white on the tip witch was runnign to hot so i changed the plug again and now it is cutting out bad but iam not sure what it could be if anybody knows or think what it could be plaese let me know thanks dan
Old Jun 23, 2005 | 09:04 AM
holeshotz8436's Avatar
if ur plug is white your runnin too lean..........try putting in a bigger main jet and/or playing with the air/fuel mix screw.........did you put a pipe or clamp on filter on your mojave anytime around when it started to do this?
Old Jun 23, 2005 | 10:43 AM
kwackermann's Avatar
Hmm- a little white, certianly doesn't sound like a too rich condition. It's probably lean, have ya done any airbox modifications?
Old Jun 23, 2005 | 02:40 PM
not to get the thred off topic but how do you like those cams kwackermann
Old Jun 24, 2005 | 12:36 AM
dkmojave's Avatar
no everything on the bike is stock. my buddy that had it before had a pipe on it but didnt play with the jets at all. but when it first starting cutting out it seem like it would happen if i was in fifth gear for awhile and then it would do it the rest of the time riding .then the next day it would be fine again . i dont know if my fan is tunning on at all and causing it to get hot .or the carb is just dirty i cant fig it out.
Old Jun 24, 2005 | 07:31 PM
Hey holeshotz, couldn't tell ya about the cams as they're on the way back from greag at cycleworks, but I can tell ya I am excited as H.E. double hockey sticks..........
Old Jul 1, 2005 | 12:20 AM
mojo21's Avatar
Sorry for responding so late on this topic but try cleaning the carb real good, I had the same prob with mine and cleaned the carb good and she runs great now.
Old Jul 3, 2005 | 12:27 PM
dkmojave's Avatar
hay i thought that might be it cause that was my last resort but i wil try that to see what happens and i will get back to you thanks
Old Jul 3, 2005 | 09:50 PM
Chris142's Avatar
Adjust the valves. They are too close and when it gets hot they tighten up even more.
Had the same problem with mine and the neighbors kids.
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
