Were to get de electric grease?
Old Sep 24, 2005 | 10:22 AM
alwaysride's Avatar
Default Were to get de electric grease?
Hey, on my last ride my fan wasnt working so im going to try so de electric grease first. I knowticed some corrosion in the connection when i first opened it up. If this doesnt work, what do i check next. Thanks.
Old Sep 24, 2005 | 10:53 AM
LTRACER's Avatar
I think I bought some at Wall-Mart before, if not any auto parts store should have it.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 24, 2005 | 01:15 PM
bfb750BF's Avatar
Autozone
Old Sep 24, 2005 | 03:26 PM
alwaysride's Avatar
Thanks, i sure hope i can get the fan back to working. If i need to, how do i hook up power to the fan power cord. Thanks
Old Sep 24, 2005 | 03:57 PM
zappa24's Avatar
I don't know if you should hook up the fan directly. If you forget to turn it on the quad might over heat. Try replacing the sensor in the radiator first and see if that solves the problem. If your not sure where it is ask the dealer and he should know.
Old Sep 24, 2005 | 05:33 PM
alwaysride's Avatar
no, im not hooking up the fan to a manual. IM trying to get it working again regurally. If the fan works when i run power to it. what else could be the prob. The sensor. Were is that at and how much would it cost to replace.
Old Sep 26, 2005 | 03:25 PM
zappa24's Avatar
The sensor should be located on the rear of the radiator somewhere, maybe on one of the corners. It will most likly have two wires coming out if it and to replace it you will need to drain the coolant out of the system. Unhook the wire plug and use a wrench to just screw out the old one and screw in the new. I am not sure how much they cost but you can check with your dealer. Good luck
Old Sep 26, 2005 | 03:34 PM
alwaysride's Avatar
Thanks. Ill have to see
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
