Installing HotCams (stage one) have question?
I ordered my cams today should have them by the weekend, what all is involved in the install. keep in mind I don't have a airbox so the should speed up the install. The biggest question I have is the timing chains. How do you lossin them? so forth. Thanks all
The trick to cam install on these V-twin motors is that you must make sure you are at TDC before you remove each head cover/cam and then re-assemble it. Then you rotate the other cylinder to TDC and remove that head cover/cam and re-assemble it. There is a wonderful write-up of how to install cams (V-force) into a Prairie 700 on Nyroc's website. Look in the tech tips section for the Prairie and you'll find it... atv.dnsalias.com
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
