Kawasaki Prairie 360 "Check Belt" light
Old Oct 25, 2005 | 03:46 PM
elderberry99's Avatar
Default Kawasaki Prairie 360 "Check Belt" light
My 2003 Prairie 360 4x4 automatic has 100 hours on it now and the "check belt" light has come on. I read where that is normal to come on at 100 hours but the service dept. tells me you have to reconnect a couple of wires but they will not tell me how to reset the light.
Can anyone help?
Old Oct 25, 2005 | 03:55 PM
alwaysride's Avatar
This is a extremly simple procedure. You can easily do it anywere. I use a small knife or screwdriver to unplug the connectors.
Procedure: under the gear shifter is some plugs. There should be two big 5 pin connectors that are black and grey, take them apart and put the in to their opposite color(black to grey and grey to black). P.S. there is actually another big connector that You might unplug and find out it doesnt fit, just plug it up and dont use it because it is not one of the plugs you want. Then after the two 5 pin connectors are switched there is a small black 2 pin connector. Unplug and and leave it sit. Turn the ingintion on for about 10 seconds watching it blink. Turn the ignition off and plug every thing back to the way it was(black to black, etc). Dont forget about the 2 pin connector also and turn it back on and it should be off.
good luck[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 25, 2005 | 04:13 PM
Do I need to remove any covers to get to the wires?
Old Oct 25, 2005 | 04:38 PM
Thanks for the help. It took me about 10 minutes total to fix the problem. I cannot believe the dealers get so much money for such a little fix.
Again, can't thank you enough.
Elder..
Old Oct 25, 2005 | 05:13 PM
alwaysride's Avatar
haha, i know, i could work at the dealers and do only those and make good mony. haha
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
