kawasaki , suzuki ,400 kfx help, water in oil
hi, i just bought a 03 kfx 400 brought it home changed the oil and found out, i got screwed.more water than oil. has anyone else had this problem i have read alot about the 400's, and never come acroosed this promblem.so check your before you buy!! if someone has had this problem was it a head gasket or worse? thanks in advance for your help
I don't think that a head gasket would allow that much water into the oil.
Is it green coolant or plain water?
If it's coolant I'd check the waterpump for a leaking seal. If it's plain water maybe it's a new Orleans refugee?
keep changing the oil...maybe owner gave it one good last beating before you got it and it took in some water...
drain the oil, pull your spark plug and oil filter off. Let it set over night and dry out...also, drain the bowl on the carb...
then clean out the cylinder head with some ether or wd-40, maybe even put in some fogging oil in. Add the fogging oil to the cylinder, carb and anywhere else you think it was wet. replace your filter, fill your oil back up, replace your plug and run it a bit...
maybe gas got water too...might want to add some dry gas...
run it for a bit and see how the oil looks...
mine was flooded pretty good a few weeks back, even had the exhaust spraying water for a few seconds after we dried the guts out and restarted...
Aug 11, 2015 11:56 PM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
