89 300 Bayou Clutch Problem
Old Oct 29, 2000 | 08:25 PM
01450ES4x4's Avatar
My uncle has an 89 300 bayou 2x4 and it has no auto clutch anymore anyone know how much it costs to fix it shifts quite hard and it will die in gear if your not moving because the clutch wont kick in. also the rear differntial lock move super hard is there any way to clean that up and lubricate it.
Old Oct 30, 2000 | 04:00 PM
rockerc's Avatar
http://www.buykawasaki.com and go to parts cataloge and find your machine.... hope this helps since it shows all the replaceable parts on the machine
Old Oct 30, 2000 | 10:33 PM
mster's Avatar
just a thought but...have you tried to adjust it yet???
Old Nov 2, 2000 | 02:39 PM
Diogenes's Avatar
Adjustment does work wonders sometimes, mster; I'm with you!
Hold upper adjusting screw, loosen locknut (12mm); turn screw right until tension is felt; then, left until tension is felt; hold screw and tighten locknut. Too far left, it won't engage; too far right, it won't disengage.
Good luck!
Diogenes
Old Nov 7, 2000 | 02:19 PM
Farmr123's Avatar
I would agree with the adjust advice. We had a 300 Bayou many moons ago and had 1 major complaint. The clutch was the most finicky for adjustment I have ever seen. As much as 1/8 to 1/4 turn made a world of difference. I think it was an 89 or 90.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
coolguy420
Jul 10, 2015 01:17 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
