KFX400 Ice Studs
I'm planning on purchasing some ice studs for winter riding. I was wondering if anyone has experience with the installation of such studs. These are the ones I plan on purchasing:
http://www.mfgsupply.com/m/c/ATV-B-500.html
Does anyone have any tips for installation?
Do you think I will have any problems installing these onto a slightly warn set of stock tires?
Any other useful information?
Thanks in advance!
Regards,
Frank
Thanks in advance!
Regards,
Frank
i also am thinking of buying stud for my yamaha blaster. they are easy to install you just get a powerdrill with hex bit that fits around the stud head and then you draw out stud patern on your tires. next drill them in one by one. the only thing is you have to have is enough tread so it dosent go throug you tire and make it go flat. before you buy the studs you should measure the tread **** and buy the stud that will work best for your tread. i hope this helped
Lou Domenech
Sep 11, 2015 06:35 PM
Jul 29, 2015 01:24 AM
