Problem with my Prairie 650...please HELP!
Old Dec 10, 2005 | 07:43 PM
big4x4's Avatar
Default Problem with my Prairie 650...please HELP!
Well, my 02 p 650 had been sitting for about 3 months without much driving. So, I take it out and immediately noticed a problem. While I would be accelerating it would lose power and almost die. Eventually, it would lose all of its power and die. I tried this over and over again with the same results! Any suggestions?
Old Dec 10, 2005 | 11:49 PM
IdahoVinnie's Avatar
I will assume that it starts right back up after dieing.
It sounds like the carb needs to be cleaned THROUGHLY, or a fuel delivery problem to the carb.
Old Dec 11, 2005 | 08:21 PM
tuffEnuf's Avatar
Check/lube your choke plungers, stretch out your plunger springs or get new ones/whole cable & plunger assembly from 03, Drain & clean your fuel bowls & jets & pilot jets. Add some fresh gas, Ensure your petccock is not clogged & Clean your airfilter and ensure no critters has made a nest in your air snorkel.
Now that it is colder you need to re-adjust your fuel mixture a little richer a tad.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 12, 2005 | 07:37 PM
handycap's Avatar
Drain all the fuel out and put new fuel in and treat with fuel stablizer.
pull out float bowl screws and drain both carbs, catch the fuel and look for dirt and sludge.
if you find anything in them, then a fuel system cleaning service is needed. Clean out tank, fuel lines, carb bowls
slowgsxr97
Mar 18, 2022 03:40 AM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
