185 Bayou starting problems...
Old Dec 17, 2005 | 06:04 PM
sandpit's Avatar
Default 185 Bayou starting problems...
It's an 85.It won't start with the electric starter.It will whirl over like crazy,but won't kick.It will pull start within 3-4 pulls???
Any idea's?
Thanks.
Old Dec 17, 2005 | 06:10 PM
IdahoVinnie's Avatar
It sounds like there aren't enough amps going to the ingition system when the starter is used. A low battery or poor connections could cause this.
Old Dec 17, 2005 | 06:15 PM
sandpit's Avatar
I tried boosting it.
It turns over like crazy,just won't kick,but will pull start in 3-4 pulls.When it is warmed up,it will start with the push button???
Old Dec 19, 2005 | 08:36 AM
dgford8200's Avatar
Don't know if this will help any or not, but check everything with respect to ignition and fuel:
1. Replace the spark plug.
2. Be sure the air filter is clean.
3. Check the battery connections (and water level in the battery).
Old Dec 19, 2005 | 03:19 PM
hondabuster's Avatar
Another thing to check is the valve clearance. If the intake valve is too tight, is makes for tough starting when cold.
Old Dec 19, 2005 | 09:27 PM
02skidoo's Avatar
My bayou 300 does this also, it will crank and crank with electric start just no fire, one pull of the rope and it is going, seems to be worse if it sits for over a week or so. I have not had any luck figureing out what the deal is either. If it doesnt start within 5 seconds of elec. starting I just pull the rope and it goes.
Old Dec 23, 2005 | 10:10 PM
sandpit's Avatar
I'll check that tomorrow.
Thanks.
rcappie4
Jun 21, 2015 07:33 PM
jgreerberube
Jun 21, 2015 02:27 PM
1000gade
May 27, 2015 12:37 PM
momofo
May 27, 2015 12:06 PM
C.bailey
May 26, 2015 09:01 AM
