P700 w/ Moose Power Mod.
I have a P700 with a Moose Power mod. Is the Copperhead CDI the same thing or something different? Can you use them both or just 1? I got the Moose unit for $80.00. How much is the Copperhead? My quad also has an HMF Pipe, Re-jetted, and a K & N Filter. Thanks for your input. [img]i/expressions/face-icon-small-happy.gif[/img]
Go to the Nyroc ATV forum. They have an almost 50 page thread on this with priceless info on the copperhead. No the Copperhead is not the same as the moose. The moose only takes the low end lag out of the engine(from 0-7mph). The copperhead will affect the whole powerband giving you not only a ton of low end power, but also power throughout mid range and the top end. The Dyna tech also makes a CDI. Theirs is cheaper than the copperhead, but does not give out as much power. The copperhead gives a little bit more low end power than the Dyna tech, and also gives it more mid range and some top end. Again try the Nyroc forum, it will give you tons of info. Hope this helps.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
