KFX 400 Spindle Shaft
Old 04-03-2006, 09:24 PM
K0NPHLiC7's Avatar
Default KFX 400 Spindle Shaft
Hey people what's up?
I'm obviously new to these boards, so i outta introduce myself before requesting help from you ATV Gurus. My names JP, and I ride a 04 KFX400. Pretty much stock, other than the Nerfs and skidplates, and tires. My problem is this.
I hit a tree goin 50mph. It sucked, big time. Fortonetly, there was minimal damage to the KFX, where that the left wheel took most of the impact. I had to repace the rim, and my rotar is tweaked a slight bit, which i will have surfaced, but I am baffeled as to how I replace the obviously out-of-wack spindle shaft. I have ordered the new parts, but I can't figure out how to get the old one from out the spindle. Any ideas? Should I just bang on it with a hammer?
Old 04-05-2006, 11:23 AM
backtrailboy2332's Avatar
When I crashed my KFX I did the same thing. The spindle bent. I went to my local atv shop an ordered a whole new knuckle for like $150.00 or something around there, later to find out i could have just bought the spindle for $65.00. If you buy the spindle at lonestar racing www.lsracing.com i think you will need to get it machined in an if yours is already bent just hammer it out cuz theres no saving it.
hope that helps.
Old 04-05-2006, 05:26 PM
K0NPHLiC7's Avatar
Ya kinda, i did buy one from IS Racing, I just don't know which way to hammer it out, lol.
Old 04-05-2006, 09:53 PM
the spindle that is bent only gos out one way. the new one gotta be pressed in
Old 04-05-2006, 10:13 PM
K0NPHLiC7's Avatar
So I have to knock the bent one out from the "back" as in away from the A-arm? And then the new one is pressed in toward the hub? Any suggestions on what tool to use to press the new one in? Rubber mallet and some lock-tight?
Old 04-06-2006, 10:46 PM
well, it only comes out one way. but idk if you can put the new one in yourself. i thought it had to be pressed in by a machine.
Old 04-07-2006, 07:48 AM
K0NPHLiC7's Avatar
Ahh. Well I work at a machine shop, and we have an arbor press that may work. Anyway, I just put my new rims on yesterday without the spindel and it doesnt wobbloe at all. I came across one major problem though, my frame is bent all to hell [img]i/expressions/face-icon-small-sad.gif[/img] It appears as though the A-Arm took the impact, and transfered it right into the frame, pushing it in on itself. Sucks. But it still rides smooth.
scrounga
Honda Side by Sides
03-07-2016 04:17 AM
Todd C Wadas
2) Chassis problems..
09-23-2015 11:31 PM
firsttimerider
09-20-2015 09:07 PM
Chasso
09-19-2015 03:06 AM
Canamaniac!
09-15-2015 06:19 PM
Quick Reply: KFX 400 Spindle Shaft
