bayou 220 question
Old Nov 20, 2000 | 01:31 PM
godmode's Avatar
My friend has a bayou 220. We noticed the front tires are angled inward. It looks to us like all the bayou's have this. Just wondering what the reasoning behind this is since no other atv does this? Is this a design flaw? Can someone explain it to me? thanks alot!
Old Nov 20, 2000 | 04:17 PM
hml4's Avatar
The reason the tires are angled inward is because the front has a independent suspension. Plus the Bayou's are very light in the front end which causes the tires to go in.
Old Nov 20, 2000 | 04:29 PM
godmode's Avatar
hrmm that all it is huh. It just seems like its more..
Old Nov 20, 2000 | 04:30 PM
P.J.'s Avatar
Correction....its because it has a SINGLE A-ARM independent suspension instead of a double A-arm. Stay in school and pay attention in geometry.
Old Nov 20, 2000 | 11:55 PM
springdrl's Avatar
Just for grins I decided to adjust the tie-rods on my 220 so that the tires appeared straight with no toe-in. It seems to have improved the way it handles and coasts.
Old Nov 21, 2000 | 12:12 PM
godmode's Avatar
how did you do that? Where is the adjustment?
Old Nov 22, 2000 | 09:52 AM
springdrl's Avatar
The tie-rods connect between the rear wheel assembly and the steering knuckle. The ends of the tie rods are threaded so that when you turn them, the rear of the wheel will move right or left creating a given toe-in or toe-out setting. I believe that wheels that are positioned straight ahead are conssidered as having neutral toe.
The rods can be rotated once you loosen the locking nut at each end. You will notice too that the tie-rod has an indentation where you can hold it with a (if my memory is correct) a 12mm wrench. Be sure to do this when you loosen the locking nuts, otherwise you might damage the tie-rod ends.
Be sure to tighten the locking nuts once you have the wheels positioned straight ahead. A good way to check this is to simply take a tape measure and measure the distance between the front of the left and rights wheels and then back of the same. Choose a the same spot on each wheel and you should be close enough for an ATV.
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
rcappie4
Sep 9, 2015 07:04 PM
