rear hub replacement?
i recently had an accident where i bent my rim and hub on my kfx400....my question is , could i put any hub roughly the same size on, maby like take 1 off a blaster instead of going and paying 160 bucksfor 2 hubs??....please put you input in...thank you
the Honda Hubs ( also some Yamaha ) fit the KFX 700, as well as the 650 / 700 Prairies... I'd guess that the axle diameter & spline count are the same as the 700's... if thats the case, you could put a Honda hub on, with the same bolt pattern...
