bent frame
Old Nov 25, 2000 | 01:52 AM
JTLAKOTA45's Avatar
i bent my frame right where the a-arms attach, its not that bad but i wanna fix it before anything else happens, so how can i fix it?
Old Nov 25, 2000 | 09:30 PM
4Tecate's Avatar
The best way is to buy a new bare frame or take it to a really good welder. The new frame is the most reliable option but the second suggestion is the cheapest. You might also want to check atv/motorcycle salvage yards. Good luck.
Old Nov 25, 2000 | 11:51 PM
trailbossman3's Avatar
take a pourta power unbend the frame weld any crakes and then take and weld a nice thick peace of metel between the two peaces of the fram that will fix any other problems I just did it to my 2000 mojave
Old Nov 26, 2000 | 11:32 PM
JD250R's Avatar
What I did when my Mojave frame bent was I stood the Mojave on it side, took a steel bar and laid from the front wheel to the rear wheel. THen I took a hydralic jack and a chain, i sat the jack on the bar and wrapped the chain around the frame and jacked until it was a it was a little to far and let it stay like that over night. then I took the jack and it should be about perfect. Then I took a piece of steel pipe about the same size as the frame rails and welded it between the bottom frame rails behind the rear a-arm mount, like most Honda's. Weld up all the cracks and you are ready to go.
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
