MOJAVE EXAUHST HELP FAST!!!!!!!!!!
ok i am thinking bout buyin the o so famous supertrap ids 2 pipe or w.e its called exactly but i need to know...do i ABSOLUTLEY have to rejet the carb...if so can u rejet a comleatly stock carb wit a compleatly stock motor....and also...i busted my rear shock and the new ones r too exspensive...i can ride it but it hits the axle or w.e alot bc only thing holding it up is the spring...can u like redo the inside??????and if so how
if you have the money spend $389 on a big gun system, you will be much happier with it and it is a way better perforrmer then the supertrapp....if you could pick one up for $150 or under go for the supper trap....the white bros e series are also great pipes......i think rols has a used trapp system for sale too lol.........as far as the rear shock, unless your mojave is a 87 the shocks cant be rebuilt.......
yes im new to this...so i think i added him as a buddy and i THINK i sent him a priv. message but as i said im a nooby so im not to sure lol... but if you can for me have him call mike at 1-217-251-0140 or email me at williammichaeladams@hotmail.com for imformation on the shock and the pipe....thanks
I cant believe it holeshot, you didnt answer the jetting question. Ya should really rejet to get the maximum preformance out of any mod you do. Also if you dont it can cause you to run to lean and that can over heat the motor. If all you doing is just a pipe and filter the stock carb should work great, unless Holeshot or roles disagrees with me, then go with what they say, they are a heck of lot smarter about this stuff than I. By the way cool nickname.
