Mud Under Seat
Old Aug 8, 2006 | 03:41 AM
fullthrottle800's Avatar
Default Mud Under Seat
I went out riding in the mud and rain broke an axle so I left the quad parked for about a month. Finally got it fixed and when I went start it it was like the battery was dead. Pull started it and my dash wasnt turning on. Find out all the wiring under the seat has corroded off from the fuse box and some other electrical components. What a brutal design for the brute force 750 wiring. Where do I start to find a diagram to try and pice it back together. Any body know what the little grey thing is in the rubber holder just back from the fuse box. It has 2 leads coming out of it. they are corroded off so i need a new one of those too.
Old Aug 8, 2006 | 08:03 PM
slynchee's Avatar
Fullthrottle,
By the sound of your description, that is a circuitbreaker for the radiator fan. There should be a little red button on the side. I hope this helps.
Old Aug 8, 2006 | 08:09 PM
squeege's Avatar
you may want to post pictures of your problem and visit the " how do I make my pictures smaller thread" if you can....
Old Aug 8, 2006 | 09:17 PM
tencubed's Avatar
Being retired is a hoot!
Spend the bucks and buy a shop service manual from your dealer parts department. Not cheap but well worth the expense. This manual will have a full wiring diagram as well as pictures/descriptions of all the component parts.
Any new equipment I purchase I always try to get the dealership to throw in a service manual. Real often they will.
When you are putting this wiring back together I would suggest you fill all of the connections with dielectric grease, this will help a lot with the corrosion problems. Good luck.
Old Aug 8, 2006 | 09:34 PM
bruteforcebob's Avatar
ruttertough.com has a brute manual download to help
badgerboy1
Sep 26, 2017 06:11 PM
Whitelx1
Oct 2, 2015 10:55 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
wrencher82
Sep 24, 2015 03:39 PM
