Help....motor seems hot
Old Sep 2, 2006 | 11:10 PM
700vtwinman's Avatar
Default Help....motor seems hot
Both my 700prairie and my 750bf ran hot and from what I understand, that is just the way v-twins run. It doesn't run hot to the point that the hot indicator light comes on, but close. It gets very hot on my left leg.....ugh!!! I have two questions. 1st, what can I run in the radiator that works better than antifreeze (ethylene glycol is antifreeze) and 2nd, is there any heat shield that I can use? I don't think the heat is coming from the exhust lead, but I could be wrong. HELP!!!!
Old Sep 3, 2006 | 01:03 AM
imstuck's Avatar
i agree hopefully somebody knows your left leg gets real hot bruteforcebob told me after about 100miles they start running cooler im at 88miles not cool yet
Old Sep 3, 2006 | 01:09 AM
greenscreaminv's Avatar
Instead of antifreeze try running Engine Ice in your radiator. It's advertised to lower engine temperatures by as much as 50 degrees. I can't say it lowers it that much, but it certainly helps. I'm not sure about any shields, but the engine ice will help quite a bit. On my kfx-700, I've noticed the fan doesn't kick on quite as much since using the engine ice. If that doesn't seem to work you may look into an aftermarket radiator thats a little bigger. I'm not sure if you can get them for those models or not, but it's just a thought.
Old Sep 3, 2006 | 01:20 AM
imstuck's Avatar
where do you get engine ice
Old Sep 3, 2006 | 08:31 AM
montyh's Avatar
i installed a temperature gauge, and i was shocked. my fan diddn't even come on until 240*. that night i installed a toggle switch (wired to the two blue wires on the temp switch on the radiator) so i can turn the fan on and leave it on. this helps, but on a long hard climb it gets hot...
the header pipe is a big part of the heat on the left leg. some guys run heat wrap and say that helps. the biggest thing i can think of is to make sure the jetting is correct.
monty
Old Sep 3, 2006 | 09:55 AM
holeshotz8436's Avatar
engine ice deffinatly works real good to lower tempertures so i would give that a try, you could also hardwire the fan so its on all the time and try one of those in-line coolers.....those are susposed to lower tempertures by 15-20 degrees too.........
Old Sep 3, 2006 | 11:42 AM
You can get Engine Ice from rockymountainatv.com It runs about $17 for 64 oz.
Old Sep 3, 2006 | 10:48 PM
Thanks for the good advice. Another question is: Do any of you have this problem? I though it just might have be my 700prairie, but when my bf750 ran just as hot, then I thought it was just the way v-twins run.
Old Sep 4, 2006 | 10:27 PM
two cylinders, twice the heat....it's just the nature of the beast.
Old Sep 17, 2008 | 06:38 PM
FeldaGirl's Avatar
Default Help....motor seems hot"></title><script src=
has any of the tips helped on the heat? I just bought a bf750i.--- Wish I hadn't. --my left leg feels like its in a fire every time I ride.---only have 12 miles on it--be a long time befor I hit the cool down of 100 miles.------Any More Tips??
