ATV turned into jetski
Old Oct 5, 2006 | 05:14 PM
Bikermikeftw's Avatar
Default ATV turned into jetski
I was riding my Polaris Scrambler 400 2002 in a Creek. I hit a submerged log and stopped dead in water up to the fuel tank. It stopped; I couldnt start it. I towed it home and found out water got sucked in the engine throught the carb. I pulled the plug and yanked on the T-Handle while water shot out of the head. I did this until clear. Now it still wont start.
I case you dont know it's a 2-stroker.
Any suggestions?
Old Oct 5, 2006 | 09:02 PM
tamiyacrawler's Avatar
There's prolly more water than that in there. Check the airbox and filter for water and clean and flush the whole carb. Change the oil too.
Old Oct 6, 2006 | 10:50 AM
Thanx; Ill try that. I didnt get a manual. ANy body know where the oil plug is? Or how I can get a cd manual?
Old Oct 6, 2006 | 11:14 AM
Ohh, it's a 2 stroker...it prolly doesn't have an oil prug then.
Old Oct 6, 2006 | 11:15 AM
NLWarrior01's Avatar
Pull off the head pipe. take out the plug, put your thumb/finger over the plug hole and rip her over a bit. That forces the water out through the exhaust manifold and does a much better job overall.
As for oil plugs, didn't think there would be one on a 2-stroke engine?? Dunno much about that though .. they just get their lube through the fuel system as I understand it.
Does your machine use oil injection or pre-mixed fuel?
Old Oct 10, 2006 | 01:56 PM
My 2 stroker Scrammy uses oil injection. It still wont start either. Sucks.
Old Oct 10, 2006 | 03:58 PM
Hayashi's Avatar
Fuel, Compression and Ignition are required for any internal combustion engine to start/run.
Make sure your carb does not have any water in it and it supplies fuel properly.
Do a spark testing - you want to see a nice fat blue spark jumping between the plug electorde and ground frame/engine when cranking.
Do a compression check - I would it should be around 150~180 psi, check your manual.
If your engine speed was high when the engine sucked in water, there is a chance of cylinder hydrolocking bending the con-rod and/or twisting the crank - the worst case scenario. Hope that's not the case though.
Old Oct 11, 2006 | 11:27 PM
RealAceRider's Avatar
scrambler 400's although 2 stroke do have a small oil tank for the tranny. i dont know were to drain it but im guessing on the bottom of the eninge toward the tranny. look for a hole in ur skid. and u can check the oil by taking off ur seat and looking between the carb and the gas tank and ull see wut looks like a over size screw. thats were u check it
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
