need some help please!
Old Oct 8, 2006 | 02:54 PM
medicman's Avatar
Default need some help please!
i have a 300 bayou and it want start in fact it has no fire to the plug when i crank it. i have tried another coil and plug and wire still nothing. the only time i see any fire at the plug is when i turn the kill switch on. and it sparks once i dont know if it's suppose to do this or not. one other thing after the ignition switch has been on for a little bit the coil gets pretty warm not sure if this is normal either. thanks for any help.
Old Oct 8, 2006 | 07:27 PM
bombrider04's Avatar
You take the plug out and ground it correct when you are doing this otherwide it won't spark at all...If you aren't getting any spark at all I would check the wiring at the killswitch to make sure that something isn't loose or disconnected then since you also check the coil and plug and wire I would say that you cdi box has gone bad and would need to get a new one...But it seems like a wire problem maybe a loose ground wire on the frame or the killswitch and controls.
