Removing shift lever shaft on 1985 185?
I just bought a Kawasaki Bayou 185 that has a shift lever spring broken in it. It shifts fine but the shift lever does not return, you have to pull it by hand. To remove the shaft and replace the internal spring, do I need to remove the right side cover to gain access to this or is there something more that needs to be done? Thanks for the help
CRamshaw777
Jul 18, 2015 05:46 PM
