Big trouble
Old Dec 15, 2006 | 08:22 PM
Cardiac's Avatar
You can take all the "shootouts" and put them in one bucket and you won't have beans.
Default Big trouble
Just got a KFX 700 and boy did I make a mistake. I had the air filter off and I happened to drop a small nut into the little hole at the rear of the airbox. It goes to a hose that is about 3/4 of an inch that runs back and into what looks like the engine block side of the clutch area. Anybody know about this hose and just how screwed am I?
Old Dec 15, 2006 | 09:08 PM
labianka's Avatar
Default Big trouble
I know about that hose becuse I ran my P650 on a three day prairie dog shoot in the dust of South dakota WITH IT DISCONNECTED!
I found it later and that was the last of taking it to the dealer.
That is a crankcase breather hose. I believe it goes into the crankcase but I could be wrong (If the engine is alot different than a P650).
I have retrieved small parts with a magnet attatched securely to weed whip line, might be worth a try.
Good luck, I know how you feel.
Old Dec 15, 2006 | 09:12 PM
imstuck's Avatar
Default Big trouble
its the crankcase breather hose pinch the hose off as far down as possible remove hose from block hope nut didnt fall in block if it did try magnet in block or shake bike side to side as hard as you can then pull drain plug hope it comes out in oil dont start motor
Old Dec 15, 2006 | 11:52 PM
Cardiac's Avatar
Default Big trouble
Thanks for the posts. I'm in a world of hurt. The nut I dropped was stainless, a magnet won't work. I will have to drain the oil and hope for the best.
Old Dec 16, 2006 | 01:57 PM
frotrk's Avatar
Default Big trouble
try a magnet on another nut. some low grade stainless have enough iron to catch with a magnet
Clark
Old Dec 16, 2006 | 08:31 PM
Cardiac's Avatar
Default Big trouble
Well, I got a little lucky. The drain hole was too small for the nut to come out, so I removed the battery and shift cables and removed the hose the nut feel down. Wow, just inside the nipple on the block was the nut, canted sideways and hung up on a very small ledge. I used a dental pick to hook the nut and out it came. What a relief. It won't happen again because I have put a screen in the hose so my fumble fingers can't repeat this experience.
Old Dec 16, 2006 | 08:38 PM
frotrk's Avatar
Default Big trouble
ALL RIGHT!
Clark
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
