chewing up loose screw
Old Dec 16, 2000 | 07:43 PM
Hud's Avatar
Hud
I had an awful snapping noise in my torque convertor.It was intermittent so I went home slowly. Took off the cover to find one of the bolts that holds the pc. of plastic that the cover bolts to had come loose and there were chew marks on my pulleys. I found the bolt in one of the breather tubes. I never found the washer. I took off belt and filed knicks on areas the belt would ride. I put some blue loctite on both bolts. Then I put duct tape over screws. Has any one had this problem? My atv is 2000 300 prairie with 400 miles on it. I think it is a bad setup where the screws can come loose and fall into moving parts.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
