prairie 360 4x4 2007
i want like to know of aftermarket performance parts i can buy for this quad. i would like to feel the power thr-out the rpm range but i would like it most on the bottom-end.
thanks for the help
thanks for the help
If you do a search on the P360 there have been a number of threads on this subject. Most folks seem to have concluded the 360 is never going to be a race machine. It is what it is, a good basic moderate speed utility 4X4.
Last time Oldmanmoses posted, at least that I saw, he had seemed to come to about this same conclusion. After doing lots of mods he had seen limited power/speed increases.
You can find some good info on Nyrock's website.
Clutch kit, will really help your low and mid range.
Also you can get a jet kit and air filter like a k/n or uni. Throw a pipe on it also.
Like previously said, not a speed demon but strong enough to do what you want with a 4x4.
leave it stock, sounds like all that was done by others didnt really knock them off their seats...
it runs ok and goes anywhere....
for speed by BF...
[img]i/expressions/face-icon-small-smile.gif[/img]
for speed by BF...
EPI make clutch kits, they seem to be the most popular on these forums. I just did a quick search on google for epi and your machine I did not see one for the 07 but I'm sure somebody can tell you if there were any changes from 06 to 07.
any know of a website that sells the kind you bought so i know i will get the right one.
how will the mod effect my atv?? will it rev up more before engaging the belt???
is it easy to install?
thanks
thanks
Just install the black secondary EPI spring, you dont need to do a whole clutch kit, I messed with weights & primary spring & it did nothing.. The black secondary will make it much more responsive, the stock spring (at least for the 2003 model) was to weak...
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
