i read this some place and was woundig if any one has dun these mods
Old Apr 8, 2007 | 11:23 PM
trailblazermudrunner's Avatar
Default i read this some place and was woundig if any one has dun these mods
A couple of do,s and donts I would suggest to 360 owners:
Dont run high test gas--Mine runs best on regular
Dont modify airbox
Do install an aftermarket air filter(although I have switched between my stock filter and my twin air and felt no difference, I will continue with the twin air element.)
Do install the black EPI secondary spring and remove the secondary shims. (this mod definitely helped low end pickup)
Do make some type of protection for your oil radiator--I rammed two sticks through mine before I got smart and made a shield out of perforated stainless--Cut it same width as stock screen but about 4" longer to but up to winch mount(great fit, too bad Kawi didnt do this)
Green Slime your tires. (saved me a couple of time, even though I carry an airpump and plugs in my toolbox"always"
I havent compared mine to a stock 360 yet, but I also did an advanced timing key, and I am pretty sure I can smoke a stock P360.
Do change main jet, and do not buy a dial a jet--I cannot seem to get any response from dial a jet and my plug was burning perfect on full throttle with stock jet, but downsizing jet from stock 155 to a 150 increased my top speed on an uphill pull.
Do raise your needle jet--with my mods, I was playing around with the carb and had a small plastic washer in my tool drawer that fit the needle--immediately improved my mid range. I took out the washer and experimented with brass washers and my ultimate performance is with the needle shimmed at .060. The needle shim was one of the easiest mods I have done yet and I highly recommend it
While your in the carb shimming the needle,- the bottom hole on the slide (not the one the needle goes through) get a drill bit, I used a bit for drilling pop rivet holes mic'd at .125, and enlarge this hole--Best free mod yet--improved throttle response tremendously
I got tired of backfiring through exhaust when decelerating so I bumped my pilot jet from the stock 35, to a 38. No more backfiring or backing off when letting off the throttle.
Old Apr 8, 2007 | 11:41 PM
strings's Avatar
I did the black secondary spring and it was the best 20$ I've ever spent. Just oredered a twin air filter yesterday but when I get it I'll tell you what I think. In a couple of weeks I'm going to try the jetting and the timing advance key. Madmuddin1 did the .60 jet shim and liked it. Why don't you PM him if you want more info.
Strings
2004 Kawasaki 360 Prairie 4X4
Full Skid Plates
Mud-Lites
Moose Hand Guards
Speedo
EPI Black Secondary
Twin Air Filter
1999 Honda 300EX
2004 Arctic Cat 250 4x4(sold)
Old Apr 8, 2007 | 11:45 PM
now do u have to take the shims out of the secondary when u put the spring in or does it matter????
Old Apr 9, 2007 | 12:02 AM
strings's Avatar
I couldn't quite tell what was the shims so all I did was change the spring. You will need to get a secondary spring compressor to install the spring. I just made a compressor ( it was easy to do ) but You may just want to buy one. Still I To recomend this mod.
Strings
Full Skid Plates
Mud-Lites
Moose Hand Guards
Speedo
EPI Black Secondary
Twin Air Filter
1999 Honda 300EX
Old Apr 9, 2007 | 12:51 AM
im trying to talk mi mom into doing the spring and maybe than i can get her to let me do the carb.....now wit the spring what advantage does it give more low end pick up or topend id love to be able to pull up to a gas pump or stop by a friend that dont know what i dun yeat and beable to launch the front end up????
Old Apr 9, 2007 | 02:08 PM
strings's Avatar
With the black spring it pulls a good bit harder on launch and the mid range but unless you have a fat friend to ride on the back your not going to pull the font end up from a dead stop. I still think you would be happy with the gains from the spring IMOP.
Strings
Full Skid Plates
Mud-Lites
Moose Hand Guards
Speedo
EPI Black Secondary
Twin Air Filter
1999 Honda 300EX
Old Apr 9, 2007 | 08:06 PM
okie that alright than i just want some more power thats me
Old Apr 10, 2007 | 05:29 AM
madmuddin1's Avatar
trailblazermudrunner,
It looks like you copied OlmanMoses profile page word for word??? Did you actually do these things or are you just suggesting/reminding others of something that olmanmoses has already done.
Mud
Old Apr 10, 2007 | 09:33 PM
i didnt copy OlmanMoses page but i found it on a local atv clubs page i actual wated to do some of these mods and posted this to see if any one has dun these mods and how well they liked them and if they recomanded them to others from there own experinces........thats all
panicmanic
Sep 20, 2015 05:54 PM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
DeFox500
Jul 26, 2015 06:32 PM
Jul 22, 2015 05:00 AM
ltrmc02
Jul 22, 2015 04:50 AM
