2001 220 bayou shocks
Here you go!
The best I could do was post them here for you to view.
96 Bayou 220 shock mod picture link
I have decided to use a Drimmel tool and move the shock bolt hole in towards the washers by 1/4 inch if possible. I think the one inch extension that I made are to much and that 3/4 inch would be better.
I hope this helps.
I hope this helps.
tx those are cool. they look like they would be great if your are gonna use a plow or haul alot like you are doing. i dont haul much though. skippy i figured a way to fix the sagging springs though i was looking around and saw that moose utilities has a spring spacer kit that you put under stock springs to shim them up.
#15
yeah those are what i was talking about th link you posted was messed up you forgot the : after http moose spring spacers
