Mojave Clutch question
Old Jul 9, 2007 | 02:52 AM
Badshot's Avatar
Default Mojave Clutch question
I noticed that my clutch cable does not have much more "take up". Does the ctuch disc wear out? Is it easily replaceable? What other pieces/parts should I replace at the same time?
It will lurch forward just a bit when I put it in gear when its cold, but don't notice it when its warmed up.
Old Jul 9, 2007 | 11:52 PM
Vunit's Avatar
i just did mine...helps alot believe me...mine was worn to $hit and my quads only a 2003...your gonna probably just want to do everything over since it will all be apart...friction plates, drive plates, springs and any gaskets to complete the task...maybe even the cable itself...i havent seen it so i really couldnt tell u...that could be your only problem why it feels the way it does...but for the year of the quad its just worth it to do everything over...also make sure u buy new oil to and break her in nice and easy...
Old Jul 10, 2007 | 12:40 AM
rolsmojave3's Avatar
The discs do wear out. It is easier if you have a service manual. You'll need the frictions, maybe steels (check them for warping, or blueing (heat)) and springs for sure. Also like V said, a clutch cover gasket.
Old Jul 10, 2007 | 01:54 AM
Badshot's Avatar
Do I need to get everything from the dealership or are there other options?
Old Jul 10, 2007 | 11:45 PM
Vunit's Avatar
denniskirk.com should def have wut u want or any of those other site i told u about...probably need to get the gasket at your local dealer...
good to hear from you rols...been out riding lately???
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
200es
Jul 10, 2015 09:09 AM
