Bayou 220 Bogging
Old Jul 20, 2007 | 03:48 AM
Moparmoosexxx's Avatar
Default Bayou 220 Bogging
If give my bayou 50% throttle or more off the line it boggs and dies. it really annoys me plz help.
06 honda rancher es
-stock
94 bayou 220
-K&N filter
-K&n stage 1 jet kit
-moose 22" hand shifter
-tach/hour meter
-wider knobbys back tires
-slightly bored out
Old Jul 20, 2007 | 02:42 PM
alisonsandmindysdad's Avatar
Sounds like it's starving for fuel from the main jet circuit. Have you pulled the carb off and removed the float bowl to see if there is crud in it and also in the main jet? Also, could the screens in the tank be plugged? Pull the fuel line off first to see if it has adequate fuel flow. Assuming it does, I'd pull the carb next.
Old Jul 20, 2007 | 04:42 PM
i have gone through my carb with bviggetr jets and i turned the fuel air mixture screw out pretty far. but i did not no about the screens in the tank. thnx
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
rcappie4
Sep 9, 2015 07:04 PM
