engine smokes
Old Jul 30, 2007 | 10:51 PM
cf1's Avatar
cf1
Default engine smokes
i have a 1993 klf 400 4x4 bayou. its started smoking like a freight train after i changed the oil.. befor i changed it it was starting to smoke very little.. i was planing on selling it and buying a new one.. how do i get it to stop smoking? thanks
Old Jul 31, 2007 | 10:41 AM
bayourider123's Avatar
well what color is the smoke if its black you are getting to much gas if its blue you are burning oil whitch is most likely rings and if the smoke is white then you have water in your gas or oil.
Old Jul 31, 2007 | 02:59 PM
cf1's Avatar
cf1
its white smoke.. my son just changed the oil, but he put regular oil in it, and i was using synthetic.. also theres no water in the oil.. my son put huskee oil 4 cycle 10w30 from tractor supply, maybe i should put synthetic oil back in it.. i want to get rid of it needs a starter clutch, and i have to kick start it.. im looking at the 750 kawasaki or the polaris800..
Old Aug 1, 2007 | 10:16 AM
i would try the oil like you said if that does not work drain the gas and put new gas in the tank and carb. b/c white smoke means theres water somewhere in your system
Old Aug 1, 2007 | 05:00 PM
cf1's Avatar
cf1
<div class="FTQUOTE"><begin quote>Originally posted by: bayourider123
i would try the oil like you said if that does not work drain the gas and put new gas in the tank and carb. b/c white smoke means theres water somewhere in your system</end quote></div>
i put synthetic back in its a little less smoke now. to touch the engine its seems hot to the touch.. its still got power and stars good.. the oil i took out had no signes of water.. i drained the gas no water.. im going to change the thermostate. the water pump seems to be working ..i can feel the pressure in the hose pumping...
Old Aug 1, 2007 | 05:51 PM
TacticZero's Avatar
white smokes= anitfreeze not water
Old Aug 4, 2007 | 10:02 PM
cf1's Avatar
cf1
<div class="FTQUOTE"><begin quote>Originally posted by: TacticZero
white smokes= anitfreeze not water</end quote></div>
the engine dont take any coolant, theres no coolant in the oil, iv changed the oil twice.its whit smoke but oil smell.. i figure the ring is gone.. is there any kind of treatment i can get to stop the oil consuption and smoke???
Old Aug 5, 2007 | 11:51 AM
its not the rings because the smoke would be blue
Old Aug 5, 2007 | 12:10 PM
Doctorturbo's Avatar
GOT BOOST!
The first thing I would do is:
#1 Check to make sure the sump is not over filled. (and with the correct oil)
#2 Do a compression/ Leak-down test. (quit guessing, this test will tell you a lot.)
#3 If those two come out ok, about your last option is start tearing the top end off and see what's up.
PS for those of you that think oil can only smoke blue, you have never seen a turbo blow a seal!!!! Jame Bond has nothing on that. Tons of cotton white smoke.
Old Aug 5, 2007 | 01:36 PM
cf1's Avatar
cf1
i will try a compression test on it.. if i knew how much and where to get the parts i would tear it down and rebuild it.. but how much and is it woerth it???? thanks guys
dirt ryder
Sep 27, 2015 09:22 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
