Help!! 2000 Kawisaki Mojave 250
Old Aug 23, 2007 | 10:36 PM
kawirider's Avatar
Default Help!! 2000 Kawisaki Mojave 250
I have a 2000 Kawisaki Mojave 250 that i purchased about a month ago. Ever since i have been riding the bike it been stalling on me. If i ride and get it heated up and stop and shut it off to take a break, i wont be able to get it started again. Also when i just try to leave it idle it will stall. The only way i can get it started after this happens is compression or leave it sit for a while.
Can anyone help me with this problem?
Thanks Ron
Old Aug 24, 2007 | 06:19 PM
holeshotz8436's Avatar
It sounds like it could be running a bit lean and heating up a bit too much, what color is the plug and have you tried messing with the air/fuel and idle screws?
Old Aug 25, 2007 | 06:39 PM
scottphillips88's Avatar
just make sure your plug isn't white. If it is your getting way to hot and need to jet up. You probably should buy a brand new plug to test this.
Old Aug 26, 2007 | 02:31 PM
kawirider's Avatar
I changed the plug and it wasnt white is was carboned up. It's not overheating because that fan barley runs because isnt hot enough. Another person told me to check the valves. Do u think that could be the problem.
Old Aug 27, 2007 | 02:55 AM
If it was my bike I would take it into a shop and have them clean out my carb real good and maybe rejet and adjust screws where neccesary. I like to play with my own stuff, but in the end I don't wanna mess anything up. You could atleast see how much this would cost....there are some great little businesses in my town that are a ton cheaper than a dealer and still do a great job. good luck and keep us updated.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
