Kawasaki mule 3010
Old Sep 16, 2007 | 10:47 PM
dongill's Avatar
Default Kawasaki mule 3010
It seems my 2006 Mule will not start. Normally you had to be in neutral before the Mule would start. The battery and starter are OK. It apparently has to do with the position of the gear shift. Is there an electric switch that monitors the position of the gear shift that may be malfunctioning? Thank you for any help you can give!
Old Sep 17, 2007 | 05:03 PM
Hayashi's Avatar
Some possibilities.
> Physically gear is in neutral but the neutral switch is not working and it is not sending a signal to the ECU. Bad neutral switch.
> Physically gear is NOT in neutral but the shifter is. Shifter linkage adjustment issue.
> Physically gear is in neutral, the neutral switch is working but it is not actuated because the shifter linkage is not making a full contact with the switch.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
shimanok2
Jan 29, 2016 07:37 PM
wendal
Sep 15, 2015 01:50 PM
