2001 mojave ?'s
Old Sep 23, 2007 | 12:37 AM
ragnredneck's Avatar
Default 2001 mojave ?'s
hello, once again i am back in atv's/i have a ? for u?
my brother in law has a 2001 mojave.
1)when we go to use the headlights ,its very dim,but when you give it gas,it gets brighter?i am thinking the stator is bad????
2)when you make a sharp turn with the quad,it wants to bog out n die and sometimes it does?when you are going straight,its fine!i was thinking maybe the petcock is clogged or ther eis dirt in the bottom of the tank??
Old Sep 25, 2007 | 05:09 PM
Hayashi's Avatar
1). Stator should put out about 14 volts and 13 amps at 4000 rpm.
2). Check the fuel line around the handle bar / steering stem area for any kind of routing problem - such as the fuel line getting pulled when handle bar is turned sharply.
Old Oct 26, 2007 | 12:42 AM
skokie's Avatar
That is normal for the head light. It does not have a battery. so when you rev it it's producing more power to the bulb.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
