problem with my 05 kfx700 v force
Old Oct 11, 2007 | 12:38 AM
skubasteve6665's Avatar
Default problem with my 05 kfx700 v force
ok so its been running great up until the other day at sand lake when i layed into it and about halfway threw the throttle it just starts cutting out coughin and spitting and sputtering and now it does that every time i give it more then half throttle?
any ideas i already re-synced the carbs that didnt do anything it will idle fine and run good until half throttle
and no the check belt light is not on that already happened a while back
Old Oct 11, 2007 | 02:23 PM
Hayashi's Avatar
How is the cylinder compression?
Runs any better with the choke 50% on or air box lid open (but not both together)?
Check cam timing as well. The chain might have skipped a tooth or 2 on the cam sprocket. Then, it would start/idle ok but would not run well after that.
Old Oct 12, 2007 | 12:33 PM
frotrk's Avatar
make sure the chokes are opening all the way
Clark
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
