Clutch housing drain plug
Old Oct 15, 2007 | 01:29 PM
94sport400L's Avatar
Default Clutch housing drain plug
Got stranded for a little while out on the trails this weekend. Tried to go swimming with the quad and it didnt appreciate that too much. Got water into the clutch housing and couldnt go anywhere(belt slipping). Couldnt find a drain on it so had to remove a plastic vent hose from the rear of the housing and stand the quad up. Up and running after 10 min.
1. Do these quads have a drain for the clutches - looked and couldnt find one.
2. Would it be difficult to add one?
3. Should i remove the outer cover and clean the clutches
Thanks
Old Oct 15, 2007 | 04:39 PM
Hayashi's Avatar
1. No, P300 doesn't.
2. No, it wouldn't be difficult. Try to find a plastic drain bolt, 1/2" min. If not, see if you can add an O-ring to better the seal.
3. If just water got in, no need to remove the cover. If it was muddy/silt type, I would remove it and clean out the abrasive debris which might chew up the converter sheaves.
Old Oct 15, 2007 | 05:21 PM
Im thinking the water came in from the front vent tube.
Guess i'll have to take the cover off and give it a good cleaning. It was a little muddy.
Maybe an easy time to go ahead and add a drain to it.
Thanks for the reply...
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Jun 2, 2019 07:25 AM
chammerbeck
Jul 17, 2015 08:06 AM
200es
Jul 10, 2015 09:09 AM
Shifts
Jul 3, 2015 07:59 AM
