03 Prarie 650 4x4 (piston trouble)
I recently put back-up lights on my 03 Prarie 650 4x4 w/ a toggle switch. While I was doing the wiring, I had a mishap w/ the electrical tape coming off and the hot wire grounding out. I thought I caught it soon enough and pulled it off but now, since that happened, I have 1 of the pistons not firing. Why would a short from the battery/ toggle switch wire cause one of the pistons not to fire?
Actually just look at the grounded spark plugs when they are out of the cylinder heads and laying on the block or heads. If one isn't firing, swap the coils side for side like Hayashi said. This will tell you if you have a bad coil or not.
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
